Is this where they go?
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Is this where they go?
Post by amorti »
DK-Tandy wrote:i found it rather hard to get the carbs out the rubbers.. i knew it wouldnt be a loose fit but feck me, it took alot of wiggling and jiggling to get the free.
You can put some silicon grease on the rubbers to aid fitting and removal. Don't use mineral grease though, as it will rot the rubbers.
Townsend87
Post by Townsend87 »
Hi,
I had my NC23 restricted for a while as it was my first bike too.. One problem which i found was that the restrictors rotated about themselves when in use, leaving the intake hole(s) at different increments. No number of carb removals and refitting rectified this and the cards were on snug. This may have affected performance as i only could get 70-90mph out of her.
i put up with this though, however 6 months later when i de-restricted it blew my mind how quick it was. That was a good day.
C
amorti
Regular Member
Post by amorti »
Townsend87 wrote:Hi,
C
The holes should be along the bottom as shown as this allows (although restricted) a straightest-possible intake path. If they were at different angle, that could potentially also give the effect that the carbs were unbalanced. I never heard of this problem, on my CB-1 the washers fit quite tightly into the rubbers. Are they smooth on the inside or is there a step? If there is a step, put the rubbers under it to make it more snug.
Vibration in that area is pretty mad, anything loose will move about.
Wozza
Post by Wozza »
DK's restrictors are my old ones, they fit nice and tight, no movement.
DK-Tandy
Bike owned: CBR400RR NC23
Post by DK-Tandy »
since ive fitted them my bike wont start :O
ive tried it that many times and throuhg putting alarm on, my battery has gone rather flat but i cant fecking get the battery out to charge it
angry_rob
Post by angry_rob »
You shouldn't need to take the battery out to charge it. Have you tried bump starting it?
DK-Tandy
Post by DK-Tandy »
i cant, i took the rear wheel out and the chain is that shit its moldable because the links are so stiff. i can't get the chain around rear sprocket or even get the front sprocket off to try and replace them...
DK-Tandy
Post by DK-Tandy »
WOOT, the genuis that i am, i fixed it..
on the carbs theres a black box which i first thought was the CDI box but it had a thick pipe on it. i took the screw out and there was a sticky out end with no pipe, the fuel leak was because the pipe wasnt connected to the carb so fuel pissed everywhere..
ii felt such an idiot as i didnt bother checking to ensure all pipes were put back on the carb when i re-fitted it
