Can you top this
iSparkzz
- Bike owned: NC35
Re: Can you top this
Well im speaking to a member on here at the moment who has offered his help to me, so hopefully that all goes well, but if anyone else wants to pitch in then they are more then welcome :)
ill make a build topic in the coming weeks and ill start posting up my parts as they arrive :)
- thunderace
- Bike owned: R6, YZF600R
iSparkzz wrote:Only problem is i have knuckle busters which my mum calls tools...
I would love to take her apart and learn her back to front but without proper tools & space then it is quite hard..
You're not talking about your mom in the second paragraph are you?
iSparkzz
- Bike owned: NC35
thunderace wrote:iSparkzz wrote:Only problem is i have knuckle busters which my mum calls tools...
ahahah no mate sorry. dont need to get your hopes up like that
LOL..you have a twisted mind
iSparkzz
- Bike owned: NC35
Ok so i have bit the bullet and i am going to give some of this a go on the weekend with a mate, but i have a few questions...
Q1: With a brake fluid flush is it the same as cars and do you bleed it up the same? And what DOT fluid do i use?
Q2: I am doing a rad flush, how do i bleed up the radiator?
Q3: When i dump my oil and put new oil in and a new filter, do i get oil pressure like a car?
Q4: What grade fork oil do i use? And can someone help me with this as this is my biggest fear as i have never done anythign like this.. so could someone give me a run down on how to do this properly or link me to a vid, thank you.
SIMILAR TO CARS BUT TAKES LESS TIME AND EASIER - DOT 4
UNDO THE BOTTOM HOSES AND PLACE A BUCKET UNDERNEATH, BLEEDING JUST FILL THE FRONT RADS UP, SQUEEZE HOSES TO RELEASE ANY AIR UP, POOR STEADY AND SLOWLY, IVE NEVER HAD ANY ISSUES BLEEDING OR FILLING RAD SYSTEMS I MUST BE LUCKY
THERE IS AN OIL PRESSURE LIGHT BUT IT NEVER COMES ON AND WHEN IT DOES ENGINES GOES BANG
DOWN TO PREFFERENCE I USE 10W SILKOLENE VERY HAPPY WITH IT JUST POST QUESTIONS AS AND WHEN YOU DO IT, AND GET A HAYNES MANUAL BEST £15 YOU CAN SPEND.
iSparkzz
- Bike owned: NC35
Thanks for that mate :)porndoguk wrote:Ok so i have bit the bullet and i am going to give some of this a go on the weekend with a mate, but i have a few questions...
Well its my daily ride so what is a good grade fork oil for me. i have a pillion sometimes but very rearly,
10-15w
10 is fine tbh but if you want its a little stiffer go for 15w
For my tuppence, don't be using heavier oil to mask the lack of correct springing in your forks.
15w oil doesn't really help, apart from making the forks les reactive and therefore less capable of doing the job.
10w oil is bob on. If you need to get the front end stiffer, you need either new springs, or to fit some silghtly larger spacers to ramp up the preload on the current springs.
Regarding flushingthis and that - it is only a big pushbike with a motor. Not really flushing so much as trickling compared to a car
iSparkzz
- Bike owned: NC35
10w it is, also where can i buy a haynes manual and download it as a pdf, i think i read somewhere that i can download it off here and support the site
