CBR400RR NC29: Fuel injection based in Microsquirt EFI.
PARUS
Re: CBR400RR NC29: Fuel injection based in Microsquirt EFI.
Post by PARUS » Sun Dec 12, 2010 10:05 pm
Received all other stuff.
1. Innovate LC-1 Bosch 02 Sensor and Lambda. Really this is good thing ever for bike without fuel injection, because easy allow you to detect are you running LEAN or RICH. You can trace air\fuel ration (AFR) with laptop or gauge.
Image Image
2. Desided to change NC29 temperature sensor with MyChron. Because one-wire temp sensor give a lot of noise and not desirable for the fuel injection.
3. Knock sensor from CBR600RR. Look like you can use from car, this is one little bit smaller.
4. Intake air temperature sensor. From CBR600RR
5. Fuel pump with fuel level sensor. Also from CBR600RR. Need to fabricate fastener to fit this to NC29 fuel tank.Image
6. Bought full wiring from CBR600RR, because it cheaper than getting individual connector for other stuff. And it also had small automotive relays - I think it can be also use in project to save some room.
7. Undertail unit with LED turn signal.
8. Added LC-1 Innovate o2 sensor\controler circuit to wiring diagramm.
http://www.moto.kiev.ua/users/parus/CBR ... g_loom.tif
PARUS
Post by PARUS » Tue Dec 14, 2010 2:41 pm
What do you think about such type of RamAir ?
Fabricate simple model of the ram air I'm planning to use. Of course, there is no dirrect airflow like in HRC airbox, but should be not big difference and you will be able to use stock airbox, and do not need to looking another place for HT coils.
This is just model, will be done from carbon soon.
PARUS
Post by PARUS » Sun Dec 19, 2010 8:13 pm
So, noone having any idea about such ram air ?
PARUS
Post by PARUS » Wed Jan 05, 2011 5:39 pm
Busy with wiring for now. When all wiring will be done - make one more video with bad english. :whistle:
PARUS
Post by PARUS » Wed Jan 19, 2011 2:28 pm
1. Updated wiring loom.
- used CBR600 Fuse box, instead of using many separate fuses and automotive relay.
- added bank angel sensor
PS: Don't be sirprised when I join different color wire, I'm trying to use CBR600RR 07 wiring, but sometimes same wire has different color.
TIFF-file: http://www.moto.kiev.ua/users/parus/CBR ... g_loom.tif
PARUS
Post by PARUS » Mon Mar 07, 2011 2:46 pm
IAC Stepper motor controler for Microsquirt. Hope to test it soon.
http://www.youtube.com/watch?v=MhoLST4WaS8.
PARUS
Post by PARUS » Wed Mar 09, 2011 12:48 am
amorti
Regular Member
Bike owned: CB-1, MSX125
Post by amorti » Wed Mar 09, 2011 8:48 am
PARUS
Post by PARUS » Wed Mar 09, 2011 3:24 pm
Guys (not from this forum),
Asked me to show how and where I fit Microsquirt, Mychron, PWM Controler. Just made quick video that all done inside of subframe.
PARUS
Post by PARUS » Tue Mar 29, 2011 9:10 pm
Mychron speed sensor http://www.youtube.com/watch?v=zAQPQ2brR9o
Camshafr position sensor http://www.youtube.com/watch?v=b1GuMd_Bhak
Fuel pump adaptor http://www.youtube.com/watch?v=vaq3NUxHKxc
Sorry, all in russian. To lazy to make both in russian and in english.
