Aha. Time to service the sliding pins then... caliper was dually removed & the bracket cleaned, relubed and rebuilt.
Still same problem... removed caliper again, eased pistons out against an extension bar & carefully cleaned, lubed and pushed them back in, didnt look too shabby to be honest? Sliding bracket now has new sliding pins & seals, everything is rebuilt.
Nope. same problem... discs & pads are good, master cylinder isnt sticking in/on at the lever, brakes rebled with new braided hose a few months back in the Summer?
Fluid is midway between Hi & Lo in the reservoir, wheel will jam up on brake being applied, freeing on a palmthud to the r/h caliper - which would indicate to me pistons sticking/seal problems, master cylinder problems would cause both brakes to stick?
Just called DSS to check if this kit (P/no: CK CBR400RJ-K F)contains all eight seals, they are closed until the 4th...
WTH??
http://www.youtube.com/watch?v=kgpY_oGINU8
