Rear shock removal
Wacko Jacko
Rear shock removal
Post by Wacko Jacko »
To remove the rear shock do you have to fully slacken the preload or is this not necessary.
If it is neccessary do you require a c spanner to do it?
Re: Rear shock removal
No need to adjust the preload but removing the exhaust does make life easier although its possible with it still fitted.
banoffee
Post by banoffee »
got mine out without touching preload nor the exhaust. an abba stand is a godsend for this job.
Wacko Jacko
Cheers gents luckily I already have the exhaust, rear subfamre etc removed so that should make it easier. I'm glad that you don't need to slacken it to remove that saves me a job.
Thanks for the advise
