600 supermono
- abrmoto
Dgeoff33
- Bike owned: RVF400 - ZX636
Re: 600 supermono
Me toomarcus57 wrote:top work , will be keeping a eye on this
- mattUKNC
- brooky
- Bike owned: cbr400,vfr400,crf250,ktm200exc
Re: 600 supermono
nice project, fancy something along these lines
Vinylmark signs - for all your bike, car, van, vinyl needs, one off tshirts also printed.
http://www.vinylmarksigns.co.uk" onclick="window.open(this.href);return false; email sales@vinylmarksigns.co.uk
- blodnob
Re: 600 supermono
Had a bit of a closer look and the sprocket hieght was a little low so i'll have to have the engine tiped down a little to bring it into line.
I'll make the engine mounts up soon and get them tacked on. No need to make em permanent as i'm just using this frame to mock it all up.
I'll get a frame with log book etc and it could end up on the road.
Engine angles not to critical as its a dry sump engine.
- blodnob
Re: 600 supermono
Just foud a big bore Wiseco piston on Ebay
I have a new 680 liner, new con rod and gasket set. Need bearings and a cam then the lumps finished.
May try bigger carbs once its running.
Build a better mousetrap, and the world will beat a path to your door.
http://s705.photobucket.com/albums/ww59/blodnob/
marcus57
Re: 600 supermono
what sort of bhp will it make?
- alexwitham
Re: 600 supermono
I'll have a stab in the dark at 65hp
- blodnob
Re: 600 supermono
I'm after between 55-60.
Dont know what the total weight will be but again i'm being ambitious and want it around 110kg max.
Friend of mine used to race supermono's and when he built em he'd be looking at keeping it under 100kg's.
I cant afford the carbon bodywork. But fibreglass is still fairly light.
I know there's a bit of stuff still to be bolted on, but at the moment i can still lift it clean off the floor without much effort.
I got a 10.5-1 HC Wiseco piston last night from ebay.
Got to get some more stuff made n sold now to pay for the rest of it.
Later, Sean
Later, Sean
