Where to put reservoir?
- Hadies
Re: Where to put reservoir?
Quite a bit. The bolt was quite stiff so I had to use a breaker. And it came loose all of a sudden which resulted in a jet of oil flying out and then quite a bit more oozed out by the time I'd turned it round and tightened it up.
- ibby4585
- Bike owned: SP's
Crikey! When I did mine just a dribble came out. Not sure how it will affect the damping now! Give it a try and see what it's like!
Dgeoff33
- Bike owned: RVF400 - ZX636
I've sent you a PM about the bracket.
That system and those rearsets look nice
- Hadies
Haha cheers Geoff.I've sent you a PM about the bracket.
This RS250 shock replaced a really tired standard early type shock so it will probably be a much better improvement. I'm fairly clueless when it comes to suspension.Not sure how it will affect the damping now! Give it a try and see what it's like!
