Where to put reservoir?
Hadies
Post by Hadies »
Oi oi.
What are my options on where to hang this? All I can think off is to drill into the undertray and cable tie it on.
Anyone got a better idea?
Excuse the dirt lol
Hadrian
ibby4585
Bike owned: SP's
Re: Where to put reservoir?
Post by ibby4585 »
Can you not put it in the standard place?
Is the hose long enough?
Kris
Hadies
Post by Hadies »
Where's the standard place? The shock I took off didn't have a reservoir so I'm not too sure where its even meant to go. Cheers Kris.
ibby4585
Bike owned: SP's
Post by ibby4585 »
On the right side of the subframe are two threaded bolts for the rear pillion footpeg brackets, you need s remote bracket that fits onto those threaded bolts. It fits just under the subframe and overflow tank.
Geoff33 will have a bracket!
Kris
Hadies
Post by Hadies »
Ah right, thanks for that. The hose is no where near long enough to reach those bolts. :(
ibby4585
Bike owned: SP's
Post by ibby4585 »
In the pic it's very close to where it should be, you might need to loosen the banjo bolt on the remote and turn the remote 180degrees to give you the length!
Kris
Hadies
Post by Hadies »
I wasn't sure what to expect if I loosened the banjo. I'll give that a try and let you know if its long enough.
ibby4585
Bike owned: SP's
Post by ibby4585 »
Just loosen v.gently and turn it where needed it might have a fine jet of oil but it won't put air in the system. Hopefully!
Kris
Hadies
Post by Hadies »
I've managed to turn the reservoir around to reach the threaded bolts not without sacrificing quite a bit of oil. What are the consequences of this :?:
ibby4585
Bike owned: SP's
Post by ibby4585 »
How much oil did you loose ? Didn't slightly loosen the the bolt spin the remote and nip the bolt up again?
Kris
