Useful NC30/35 info
royster81
Re: Useful NC30/35 info
Post by royster81 »
wheel bearings are 6004 2RS
Cammo wrote:Good idea!
Front axle bolt - 24mm
Yeah..one of my bikes has a 22mm and the other a 24mm..so there!
royster81
Post by royster81 »
i think the rvf is a 22mm bolt.
spongy.bob
Post by spongy.bob »
hopefully these are handy....
"M" Length (mm) Tread (turns per mm) Gap between base of head and start of threat. (un-threaded shaft) head type Quantity
RHS of Bike engine case 6 40 1 20 Cap/cheese head H5 alan key 2
6 32 1 12 Cap head H5 10
Clutch Cover 6 28 1 8 Cap head H5 4
6 25 1 5 Cap head H5 1
Water Pump 6 35 1 15 Cap head H5 1
6 65 1 45 Cap head H5 1
6 10 1 0 Cap head H5 1
Sproket Cover 6 32 1 12 Cap head H5 1
6 70 1 50 Cap head H5 1
6 80 1 60 Cap head H5 1
6 110 1 90 Cap head H5 1
Drive cover 6 12 1 0 Cap head H5 2
Reservior bolts 4 45 1.5 0 Counter sunk H5 2
Bar end bolts 6 55 1 0 Counter sunk H5 2
spongy.bob
ok that didn't come out very well! I'll re-format and re-post.
spongy.bob
RHS of Bike engine case:
M6, length 40mm, thread (turns per mm) 1, un-threaded shaft (from base of head too thread) 20mm, quantity x2.
M6, length 32mm, thread 1, un-threaded shaft 12mm, quantity x10.
Clutch Cover:
M6, length 28mm, thread 1, un-threaded shaft 8mm, quantity x4.
M6, length 25mm, thread 1, un-threaded shaft 5mm, quantity x1.
Water Pump:
M6, length 35mm, thread 1, un-threaded shaft 15mm, quantity x1.
M6, length 32mm, thread 1, un-threaded shaft 12mm, quantity x1.
M6, length 65mm, thread 1, un-threaded shaft 45mm, quantity x1.
M6, length 10mm, thread 1, unthreaded shaft 0mm, quantity x1.
Sprocket cover:
M6, length 70mm, thread 1, un-threaded shaft 50mm, quantity x1.
M6, length 80mm, thread 1, un-threaded shaft 60mm, quantity x1.
M6, length 110mm, thread 1, un-threaded shaft 90mm, quantity x1.
Drive Cover:
M6, length 12mm, thread 1, un-threaded shaft 0mm, quantity x2.
Reservoir Bolts:
M4, length 45, thread 1.5 turns per mm, un-threaded shaft 0mm, quantity x2.
spongy.bob
That's better!
Up yours Pro Bolt! :peace:
silentRVF
Bike owned: NC35
Post by silentRVF »
My RVF is 22mm as well :)
Hadies
Post by Hadies »
NC30
Top yoke pinch bolts - M7 x 50mm Socket cap
Fork pinch bolts - M8 x 45mm Flanged hex
Ignition Barrel - M8 x 20mm Torx head
