Realistic 750cc conversion?
Re: Realistic 750cc conversion?
Turbo charging alone isn't that impractical.Giff wrote:Supercharging/Turbocharging is impractical and very expensive.
Does anyone know the weights of the 750 and 400 lumps?
Seen plenty of old 1100r's turbo'd.
No idea on the gasflow with the V downpipes though and where you'd mount a turbo. Much easier on an I4 where all your pipes join up near the front :)
- Giffin101
Turbocharging is impractical and particularly unrealistic on a little V4.
Cost wise, turbo, which you'd have to mount around the rear shock, sealed airbox, sorting the fuelling and rebuilding the engine to cope with the power.
The GSXRs you have linked to are much easier to do that type of conversion because of the type of engine (IL4) and sorting the fuelling (already fuel injected). Parts are also readily available off the shelf.
I have some experience of forced induction, if you honestly think you can stick a turbo on a little V4 then do it and post up the results.
- Bike owned: ftr223 650 bros
I rode this bike today, can't say if it was worth the effort, as I don't know what was involved.hollo wrote:Hello ,
I have a NC30 with a VFR750 engine fitted , it was covered in this topic ,
viewtopic.php?f=22&t=18988
Mike .
It handles well and turns quickly with its increased rear ride height, but the beauty is in the way it pulls .
The motor is incredibly smooth and the easy power a sheer delight, no need to keep changing down, plenty of low down power, great fun.
If the extra speed was never used, the midrange performance is so useful, it's strange to ride a "400" that shifts like this one
Dave.
Giff wrote:Turbocharging is impractical and particularly unrealistic on a little V4.
Err that bike was an 86 GSX1100.. they use tiny 32mm carbs :)
The 89 K model is what you want... they also have mikuni carbs but with werid shaped slides.. engines are rock solid though, they tune and turbo well without any strenthening required.. i'm sure they were built out of granite or something :D
As I said in my previous post the exhuast design of the V4 makes things more interesting, but not impossible.
The design of the NC21 and NC24 collector box is quite interesting.
I just like the idea as its novel and different and presents some engineering challenges while keeping the engine the same.
