Project VFR
Cammo
Re: Project VFR
Post by Cammo »
Spike16 wrote:... definetly need more modern clocks tho, the shape is timeless but the clocks are vintage
The clocks have (semi) race pedigree!
Foam mounted, separate speedo... I love the simplicity.
I don't know why anyone would want a digital speedo.
Carlos
Location: The Peoples Republic of Bloxham, Oxfordshire.
Re: Project VFR
Post by Carlos »
With you on that, I might be getting on a bit but digital things have to be read and calculated for my old brain to understand. You know at a glance where you are with a needle, like looking at a compass or when you glance at your watch. Tank mounted sundial anyone? 8-)
yayoboy
Re: Project VFR
Post by yayoboy »
agree with stick shift and carlos, the clocks look damn sweet to me, plus love seein that needle flyin up and down when your on and off the gas :D :D :D
Spike16
Re: Project VFR
Post by Spike16 »
the rx2 has a needle rev counter, the digi dash on my 50 is basicly a simple version of the rx2 with the same layout so its what im used to and prefer
Smev
Bike owned: NC30 of course
Re: Project VFR
Post by Smev »
The reason I was thinking of new clocks was to just make it a little bit more modern and make some space to mount the ignition block - but I've had an idea ;) I'll keep you all updated.
I think I'll pass on the Koso clocks now as I'm easily convinced that they are a bit too casio watch and a bit scooterish too!
Well - this weekend I attempted to check the valve shims which went wella nd they were all within tolerences too - bonus!
I also cleaned up the carbs and did the 2.5mm slide mod too :)
Last thing i did was to start it up for the first time in a while - sounded great with the new system - however it did seem to have a strange tappetty sound from the rear cylinders- specifically No 3 cylinder. Or it might have been the exhaust blowing/tapping away in tha area?
Could it be exhaust valves that are causing the problem?
But its almost ready to go back out onto the road :D All thats left to do is fit the fairing and give it all a good going over to make sure nothing has been left loose. 8-)
Mister Donut Rep NC30
Re: Project VFR
thats coming along really well, i must admit a wasnt too keen on the bike when it first appeared but its looking good now. nice spec too
Smev
Re: Project VFR
Post by Smev »
Well here she is!!
I've just about completed all the things I wanted to do (up to this point!) And its just a case of a little bit of fine adjustment and I'll be out on the road :D
Any comments welcome :D 8-)
craigs23
Bike owned: Quite a few
Re: Project VFR
Post by craigs23 »
Bike's looking very tidy, nice one.
I think you've made the right decision with the clocks. I couldn't find a replacement that I genuinely felt as a worthy change for under £500. There is a beauty in those old dials; I'd never contemplate swapping the clocks on my old Blade, for example.
Re: Project VFR
That is a lovely looking bike mate - well done.
So cool to see NC30s being looked after and turned into top quality bikes..
Carlos
Re: Project VFR
Post by Carlos »
Superb! Top marks that man! :mrgreen:
