Where does the NC35 speedo drive measure from?
- silentRVF
- Bike owned: NC35
Hey guys,
As above.. where does the RVF400 speedo measure from, and will changing the gearing of the sprockets affect the speedo and odometer?
Cheers!
Cheers!
Re: Where does the NC35 speedo drive measure from?
It runs off the front sprocket nut and so changing the gearing will affect the readings...
- silentRVF
- Bike owned: NC35
dammit
thanks for the quick reply :D
I've always got around it by fitting a digital pushbike speedo (magnet on front wheel), then you can change the gearing to your hearts content and you'll always have an accurate speedo.
