3en1 battery not charging
Re: 3en1 battery not charging
You must have grown up quick !!!
iancullen7
- Bike owned: fzr400 88 fzr600 92
got the casing off in gear wood on swingarm turning nut anti-clockwise the chain tightens up then the front sprocket slips on the chain more help needed cheers am so fuckin close
Your chain must be a bit loose then ... retension it
iancullen7
tensioned up the chain still slipping is it defoe anti-clockwise to undo if so any other ideas cheers
Well - take either the clutch cover off and jamb the fly wheel or take the starter cover off (in front of the clutch cover) and hold it on that.
