3en1 battery not charging
iancullen7
Bike owned: fzr400 88 fzr600 92
Post by iancullen7 »
as in the title battery not charging but after starting with battery pack will ride a few hundred metres the splutter and may backfire and stall now the rest is for you cheers ian ps had to push the f_ _ _ker half a mile home not happy :cry: and it was hot with all me gear on :drool:
bubbadel
Re: 3en1 battery not charging
Post by bubbadel »
Regulator/rectifier.....Maybe worth checking the plug connectors to make sure none of the contact pins have gone green, also check the red wire from the reg/rec to make sure it is live, ihad had a break in that wire and had to bypass it..
Post by Evilchicken0 »
Pull the battery out of the bike and have a look at the liquid level in the cells - if they're low top them up distilled water. If there's a lot paste between the plates then the battery's probably dead.
Charge the battery overnight and put a voltmeter across the terminals next day (with the charger detached) you should get a healthy 12v
Start the engine from the battery - or use jump leads. Then with the engine running put a voltmeter across the terminals, you should get 13-14.5 volts, if you get the same as the when the battery was off the bike then it's the generator.
Rev the engine and if the voltage goes up to 15 or more the reg recs dead.
Also check all the connections are done up and they're clean - the reg/rec is on the frame spar above the swingarm. Put a smear of vaseline on the block connector terminals (you don't need a lot) this helps to keep them from corroding and eaiser to undo).
MDS deliver batteries
bubbadel
Post by bubbadel »
I got to disagree with you Evil, if the bike is charging then it will run with a duff battery, the ignition needs 9 volts to run. I ran mine with a duff battery for about 3 months (due to lack of money to get a new one) I had to bump start mine all the time... I've had a couple of Reg/recs die, one even nearly caught alight, but it was the generator that blew that time, melting the reg.. You could do with a volt meter Ian, if you got one, start the bike on the booster, and check the voltage going to the battery, as Evil says it should be about 14.5 while revving at 4k, If there's no charge at battery check the voltage from the rectifier (red wire)
he says the bike started with the jump pack - that would have charged the battery a littl which I imagine the bike ran on until it died.
I'd say the bike isn't getting any charge - so the generator coil has probably gone.
But you need to just check through the system to make sure the generator is the cause and not the symptom of something else.
iancullen7
got myself a generator coil £18 ebay battery and the rest seem fine can i fit the coil myself or do i need someone with the know how and if i can do it myself some pointers would be great cheers ian p.s its a complete coil with the ring :oops:
As far as I know you just take off the cover and the coils inside it ... take a picture
Then undo the nuts or screws and fit the new coil.
If they are screws and they're tight use an impact driver to get them out - the last thing you need is to round the screw heads.
iancullen7
picking up generator coil from the p,o 2morrow took the cover off now theres a bolt in the centre how do i get it to stop spinning like lock it off to remove the bolt as it all spins when turning the bolt prob dead easy but i havent got a clue what am doin here :oops: :oops: but i am tryin :whistle:
Put the bike in gear and stick a lump of wood through the wheel above the swingarm - that will lock the engine and you can get the nut off
iancullen7
as i said something simple cheers evil your my daddy! :peace:
