nc 30 clutch repair will pay co durham
yamahaha
Re: nc 30 clutch repair will pay co durham
Post by yamahaha »
after all that i had five bent friction plates wasn't a lot but enough to give those symptoms .thanks to all who replied
SimNC30
Post by SimNC30 »
yamahaha wrote:replaced clutch and there is about a 5 mm gap between circlip and outer thrust casting i will be up for a while just let it ring once an i will call you back ..ian
Hi Ian,
I replaced my clutch plates over the weekend and encountered a similar problem - I stripped it apart again and got out the manual and must've done something wrong, i'm thinking that I put a plate in and it was at an angle in the basket.
To get it sorted I took all the plates out and removed the inner part of the clutch (the bit that sits in the centre of the plates, can't remember what it's called) and got out the Haynes. It advised to start building up the plates so that you've put in four friction plates and three clutch plates (don't hold me on that, but I think that's what it was) and then put in the centre piece, before building up the rest of the plates and putting the end piece on the pushrod and refitting the outer plate and pressure plate. When I put the circlip back on it still didn't locate into the lip, presumably because the clutch assembly was more built up with the newer, thicker friction plates. I'd say there was 2mm to go before it would go in properly. I got the end of an allen key and gently tapped the circlip, so the pressure plate moved enough for the circlip to expand into the lip. I did this at a few points all the way around and it fitted back in as it was meant to. Once it was in there was feel at the lever and the clutch worked fine.
SimNC30
Post by SimNC30 »
D'oh! Didn't see that last post... :whistle:
rider4life
Bike owned: Vfr 400 nc30
Post by rider4life »
My clutch is all out at the moment.....My plain plates are very blued and im gonna replace them....Hopefully that solves the problem....I've bought friction plates twice and they have been damaged. Its ended up costing £200 to replace a few clutch plates.
rider4life
Re: nc 30 clutch repair will pay co durham update!!!
Ok i recieved the steel plates from rick O today....I put them all in with my new friction plates and its still the same thing....i noticed when you look inside the pressure plate that sits on the outside , The gap where the pressure plate lifter sits in is really big and when you put the circip in theres a 3-5mm gap which is why the clutch lever just pulls on the way in with no clutch feeling.
so the next test i assembled the clutch with No friction plates or steel plates...put it all back together and its perfect theres no 3-5mm gap and the circlip is perfect....clutch has got feeling again.......Im guessing it has to be my friction plates.
One thing i didnt do properly was i only soaked the plates for 2 hours before fitting them ....could that be a big problem ?
I really need help with this asap i missed the southend shakedown last year and dont want to this year
Malc
Bike owned: NC35, 5SL, 3XV, 2MA
Post by Malc »
rider4life wrote:Ok i recieved the steel plates from rick O today....I put them all in with my new friction plates and its still the same thing....i noticed when you look inside the pressure plate that sits on the outside , The gap where the pressure plate lifter sits in is really big and when you put the circip in theres a 3-5mm gap which is why the clutch lever just pulls on the way in with no clutch feeling.
How many friction plates, and how many plain plates are you fitting? I don't know why but I think I remember reading somewhere once that some engines have nine friction plates whereas some have eight. Don't quote me on that though! 3-5mm does sound like a plate of each type thick, if you see what I mean...
Soaking the friction plates will not make them swell up, so short answer is No.
rider4life
ok i done some futhur tests.....I put the old friction plates in with the new steel plates and its working.......so i guess the new friction plates are faulty or to thick ??? ......
how thick are they?
http://akhara.com/nc30/nc30clutch.html" onclick="window.open(this.href);return false;
check this out :rocks:
Malc
Post by Malc »
CMSMJ1 wrote:how thick are they?
Thanks for posting that link CMS - its the RVF vs VFR that has a different number of each, so disregard earlier post everyone! :whistle:
