HELP!!
ChowderV4
HELP!!
having serious trouble fitting yamamoto half system,
the plate the fits it to the rear manifold doesnt seem to line up and at the moment the system is fitted as best as it can at the moment and its hitting the swing arm and wont line up at the rear?
any help?
i'll try and get pictures up
any help?
- ibby4585
- Bike owned: SP's
Re: HELP!!
Are you sure the system hasnt been bent? Its probably easiest to get it on an auxilary stand get the back wheel off and seat unit. It should go on fine!
ChowderV4
Re: HELP!!
this is where the chain almost hits and where it almost hits the swingarm
and where the footrest hits
we cant seem to get this fitted so it clamps onto the manifold
- ibby4585
- Bike owned: SP's
Re: HELP!!
Ive got a half yammamoto on my and ive looked at it, it is quite close to the right rearset but not the chain. Can't quite make out the first pic, that looks more like the link pipe to the Can?? Are you sure the link pipe is the right one??
- ibby4585
- Bike owned: SP's
Re: HELP!!
have you taken the front headers off? its far easier if you do!!
Re: HELP!!
You don't need to remove the front headers for a half system, it should all go together fine.
Take teh system off and start from the rear headers. You'll see that when the rear header plate is on the studs there is quite a lot of movement in the pipes, so move them away from the footrest.
Don't do the bolts up tight, just assemble it and move things where you need them before tightening up the rear header bolts.
ChowderV4
Re: HELP!!
the top pic is where the half system links to the yamamoto can
the problem is we did fit it rear first and the manifold plate wont push in enough to tighten all the bolts, one has rounded because it couldnt get enough thread. and we've tried hammering the plate in with rubber hammer and it wont go flush with the manifold.
and it just looks really tight by the swingarm and chain. i'll try get some more detailed images up soon.
- ibby4585
- Bike owned: SP's
Re: HELP!!
The plate wont go flat to the the rear headers as the pipes have shoulders on them. Thats what i found with mine anyway, like data says you need to loosely fit it then position it to where it clears the swingarm and the chain. Have you taken the link pipe off??
ChowderV4
Re: HELP!!
when we fitted it the link pipe was off.
it just seems very tight, i know that some race systems do cut it a little fine with the swing arm but it just didnt seem to sit properly, and whatever way you moved it it just didnt seem to be giving it space round the swing arm.
where it connects to the front headers should it slide all the way in, because mine only slipped about half way.
ChowderV4
Re: HELP!!
this is what the system looks like. bought it off deviant400
Deviant400 wrote:as you can see it has some dents and can has some scratches on it , its by no means mint but is solid and totaly usable
