Front forks
Saltire88
Front forks
Post by Saltire88 »
I currently have a set of forks with pre-load and damping.
I got another set which are from a K model.
I know the K model has conventional Damping and the others have a cartridge damper. But will I be able to get pre-load from the K model forks with my tops on them.
Re: Front forks
You already have preload on both of those forks. The later models have adjustable rebound on that brass screw.
Saltire88
Re: Front forks
Post by Saltire88 »
Always get them mixed up. So if i put my tops on the older forks will I get re-bound or am I going to have to swap internals as well.
Re: Front forks
no, you'll not get rebound adjustment
They are fundamentally different inside. the older ones are a damping rod type and the damping is by holes in the rods as it pulls through the oil.
You can tune this by different oil weight or by having a specialist weld up the holes and create new ones of different sizes. If you felt rich, you could get a cartridge emulator fitted too - never seen one, but assume they meter the oil through shims as per the cartridge in the later setup?
Saltire88
Re: Front forks
Post by Saltire88 »
Cheers, might just have to swap the stantions then, mine are all pitted.
hunter
Re: Front forks
Post by hunter »
I think the bottom of the stantions are different.but someone on this forum said they could be made to suit.
Saltire88
Re: Front forks
Post by Saltire88 »
Right time to find the manual again, lol.
royster81
Re: Front forks
Post by royster81 »
scottie the chrome sliders are different between the two models of forks.
Saltire88
Re: Front forks
Post by Saltire88 »
Ah crap.
lee.pb
Bike owned: 3
Re: Front forks
Post by lee.pb »
off subject what would you set pre load and dampening at as a rough guide for the track on the later type forks?
sorry to muscle in on the trend. :roll:
