NC24 wont start HELP.....
spooky
Bike owned: nc24
Re: NC24 wont start HELP.....
Post by spooky »
Ahh just noticed you said the vacuum pipe was not attached to the tap,Thats why it won't start then... It should be the nipple that faces fowards, But you can check this by removing the fuel pipe and connecting the vacuum pipe to either of the small nipples and sucking on the other end to see which one needs to be connected, ie only one will let fuel flow from the fuel pipe. Then you can connect it all up and it should start, You may need to turn it over a fair bit as the carbs are now empty but it should run.
As said before full choke and no throttle..
VfRTeddy
Bike owned: Vfr400 nc24
Post by VfRTeddy »
ahh cool think the tap is fooked cause there seems to be petrol flowing down the vacume pipe so will swap the tap for my old one which works hopefully
will keep u updated
Cheers all
Ben
spooky
Bike owned: nc24
Post by spooky »
Oh dear! That must be a hole in the diaphragm then. :down:
VfRTeddy
Post by VfRTeddy »
update
emptied the tank to change the fuel tap an the petrol at the bottom came out drown very very brown i think i may have to clean the carbs as i had it runnin on reserve the night before she stoped workin :cry: sould have empied out the tank when i bought it im a :wanker: lol
Ben
spooky
Bike owned: nc24
Post by spooky »
OH sh1t. hope you get it sorted then.
VfRTeddy
Post by VfRTeddy »
cheers me 2 would any of the sh1t made its way further down into the engine or would a carb clean do??
Ben
Post by Neosophist »
VfRTeddy wrote:cheers me 2 would any of the sh1t made its way further down into the engine or would a carb clean do??
Ben
It'll just clog up your carbs and jets.
Whip em off and clean them!
As for the tank... take it off and put some diesel and gravel in there and shake it gently about to remove most of the rust.
Do a seach of the net for cleaning gas tank and you'll find lots of methods of cleaning them up! I've never had a problem with the gravel myself.
VfRTeddy
Post by VfRTeddy »
ok cool cheers mate wil have to give it a go an carbs hard to do?
an how do i get the gravel an everything out?
Ben
Same way you got it in! :whistle:
Then just rinse the tank as much as possible.
It can take a while but if you take your time! (most important) and do it properly you should be fine. Have a search on the net for petrol tank cleaning you'll get more of an idea then! Theres several techniques, tips and tricks detailed on many sites!
VfRTeddy
Post by VfRTeddy »
Neosophist wrote:Same way you got it in! :whistle:
HAHAHA very funny ;)
yer will give the net a look
cheers
Ben
