NC24 wont start HELP.....
VfRTeddy
- Bike owned: Vfr400 nc24
as per title my nc24 wont start.
The story..
on sunday started her an left her to tick over for about 20mins then switched up an covered up for the night
monday went to start her an she tryed to start but nothing battery was dying an not much petrol was in it so filled her up an tryed bumping, but she would start and as soon as you pulled in the clutch she died so gave up for the night
2night tryed again after charging the battery tryed an tryed looked at everything then the starter moter stuck on even with the ignition off, key out. then nothin from the button. gave up again after another 2hours checking and tryin
any help would be muchly appreciated
sorry if any of you fell asleep while reading this
many thanks
Ben
The story..
many thanks
Ben
Re: NC24 wont start HELP.....
Hmm.. if the starter motors stuck on your solenoids buggard.
It's the little metal canister that sits by the battery.
Try tapping it with the handle end of a screwdriver and see if it frees off.
As for not starting.. make sure you have a FULL battery.. full choke no throttle until its running.
Lets go from there and see how we get one.
My NC didn't start after being laid up for 2 months even though it was cranking.. conected it to my cars battery and away it went.
VfRTeddy
ok cheers will give it a go, just weird it stoped workin less than 24hrs after it was last started
Ben
Ben
- spooky
- Bike owned: nc24
Also check its getting fuel as the vacuum pipe may have split or kinked.
VfRTeddy
which pipe is the vaccum pipe? cause i have had a wee bit of a petrol leak
Ben
Ben
- spooky
- Bike owned: nc24
Its the small diameter tube that goes from the side of the left rear cylinder on the engine to the fuel tap. It sucks the diaphragm open to let fuel flow through the tap. There should not be fuel leaking through it.
Also check the cut out switch is not off on the handlebars.Easy mistake but it happens to everyone at some time.
Is there any smell of fuel at the exhaust?
Is there a spark?
Is there a spark?
VfRTeddy
ahh right cool i will check that 2morro
ta
Ben
ta
Ben
- spooky
- Bike owned: nc24
Sort the leak out as a matter of urgency mate as it will melt the plastic side panels and destroy the paintwork or even catch fire
If its leaking from where the tap is mounted take it off and clean it, then use blue hylomar sealant on it. It will not leak then.
VfRTeddy
yer that leak has been stoped now. i didnt even know it was leakin an my mate said he could smell it a mile away lol gotta love colds
ta
Ben
ta
Ben
- spooky
- Bike owned: nc24
