nc 30 carb balancing vacum points
big cheese
Bike owned: VFR NC30 DUCATI 748
Post by big cheese »
hi all going to have a go at balancing the carbs on my vfr nc 30 got myself a set of gauges but can,t find where to connect the vacum pipe for the front right inlet manifold,there do not seam to be a blanking screw for that manifold,if that is right where do i connect the 4th gauge to,or do i only use three can anyone help please
Re: nc 30 carb balancing vacum points
There is a little brass screw in each inlet. should be obvious.... ;)
DoktorMandrake
Bike owned: NC35 & NC30 x3
Post by DoktorMandrake »
The only one I had trouble locating was on cylinder #4 (front right) as it seems to be in a diff position but from memory it's the easiest to get to. To be safe I'd make sure you screw your adapters in when the engine is cold and let it cool thoroughly before you remove them or you can end up stripping the tread and then you'll be in a whole world of shite.
big cheese
hi guys still unable to find the blanking screw for the front right inlet found the other 3 can you point me in the right direction,thanks
Post by Neosophist »
big cheese wrote:hi guys still unable to find the blanking screw for the front right inlet found the other 3 can you point me in the right direction,thanks
the one by the thermostat? look on the corner of the cylinder behind it
micpec
Post by micpec »
Agree with neosophist....it should be near/behind the thermostat unit (did my NC35 recently, I found it after a few minutes of searching :peace: ) PS: Have you got a haynes manual?
big cheese
nice one guys found it can get on with the balencing now thanks again ,does it matter weather the air box is on or off and the plate that holds the trumpets is there any tips as to how to get that on to the carbs nice and easy,
Cammo
Post by Cammo »
big cheese wrote:nice one guys found it can get on with the balencing now thanks again ,does it matter weather the air box is on or off and the plate that holds the trumpets is there any tips as to how to get that on to the carbs nice and easy,
It will be best to balance the carbs in the setup that the bike will be run in (airbox on etc).
Getting the carb top plate on can be a pain. It helps to loosen the screws that hold the 4 carbs together (on the ends) so you can jiggle them a round a bit.
Deviant400
Bike owned: NC30, Kona Cowan
Post by Deviant400 »
wish i knew that when i removed that plate once,(first time i removed my carbs) i nearly threw my carbs at the wall trying to get that c*nt back on :whistle: then i realised you dont need to remove it to take the carbs off,,,,doh!!
Deviants AM/PM build
viewtopic.php?f=62&t=27307
DoktorMandrake
I did that too. Seemed logical to remove it... at the time... :whistle:
