NC30 wont start :(
majormadass
Bike owned: CBR125R, VFR400 NC30, RVF 400
NC30 wont start :(
Post by majormadass »
hey guys wondering if you can help me, for some reason my NC30 89 model wont start all of a sudden, me and my brother checked and cleaned the carbs, and also the jets and cleaned them aswel, and finally changed the vacuum hose, the bike now tries to start up but slightly splutters and also backfires when trying to start, this showing fuel is going through, but the bike still wont start, the only thing it can be is the spark plugs, if anyone has any other ideas please let me know! gonna check the spark plugs and change them in a few hours, will give an update, any help will be much appreciated :grin:
Re: NC30 wont start :(
Could be plugs, ive killed a brand new set of plugs before by flooding them. Had similar symtoms as youself when trying to start it
Cammo
Post by Cammo »
+1 for flooded.
majormadass
hope so guys, just got 4 NGK spark plugs, and gonna fit them soon! because ive checked everything, airbox, air filter, carbs and jets cleaned, also new vacuum hose, charged battery =/ only thing left is the spark plugs, ill let you know how i get on
majormadass
hope your right guys!
majormadass
Drunkn Munky wrote:Could be plugs, ive killed a brand new set of plugs before by flooding them. Had similar symtoms as youself when trying to start it
hey you seem to know a lot :) i seen a post with NC30 problem, something about the coils and stuff? if i change my spark plugs and check wires and my nc30 still wont start, would i have to replace coils? if so you got a rough idea of how much it would be, because its similar to that other guys post, over winter it was locked up in my garage, and i went to go out and wouldnt start, like i said ive checked everything apart from spark plugs, gonna check them soon, if that doesnt work any idea mate?
Get them new plugs in and try it, like i said ive killed a brand new set of plugs before and messed about for days checking and refitting everything else only to find it was the plugs :oops:
If it doesnt want to play ball with the new plugs in dont keep going and flood the engine or you risk killing the new plugs, its easily done. The coils can be checked in a way. If you havent already get youtself a haynes manual and read up on checking your electrical system, if your coils are shot i wouldnt have thought they will cost much to replace but my moneys on the plugs.
majormadass
Drunkn Munky wrote:Get them new plugs in and try it, like i said ive killed a brand new set of plugs before and messed about for days checking and refitting everything else only to find it was the plugs :oops:
got haynes manual buddy :D my bro wouldnt be too happy as he's helped me check carbs and jets clean them, charge battery everything!, and i said check spark plugs but he's adamant its not them, hes a fairly good bike mechanic after doing it at college for 3 years, ive got 4 brand new spark plugs ready mate! ill let you know how i get on!?!? do you have msn messenger!
na, stick around on the site, everything i know about these bikes ive learned on here.
Cammo
Post by Cammo »
You can kill the plugs just by using throttle when starting them...
Fit the new plugs, and start it using full choke and NO throttle.
Odds are it will fire up straight away.
