WELL WELL
Project exon valdez is go. Its only been on its maiden run on the road, and only passed its MOT too.
Passed MOT with no issues, however he did comment on the alignment of the front wheel was slightly to one side.
after a bit of a waggle and check, he suggested we slacken it all off let settle and tighten, which we did and that sorted it. however i do wonder if the bottom yolk was slightly pissed. got a spare so can change it anyway.
apart from that no faults, and it rode reasonably well apart from feeling like eggshells on brand new 090's and gritted roads in a hell of a mess.
However after its maiden 20 mile run i can see there are cooling issues. it crept up to the top and went rather wooley when hot, so i need to check the cooling system, inc pump and thermostwat as rads are perfect.
speedo - reads a bit low after a had the needle off to put a sticker on. oops i put the needle on wrong then.
rear brake is wank.
fueling - it runs ok, perhaps a bit rich tbh and i want to ensure its not leaking fuel with a sticky float.
replace some fastners with better ones.
on the upside, any fears i had with the engine were wasted, it runs nice and strong and the gearbox is a peach. clutch is a bit wooly perhaps.
