NC23 rear disc
cress87
- Bike owned: NC23 CBR400RR
NC23 rear disc
Chaps,
I need a new rear disc because mine is slightly warped. Does anybody know how much they cost from Honda? Where is the best place to get them?
I've also seen these rear discs. Has anybody used them and are they any good? They seem very cheap, perhaps too cheap if you catch my drift...
Thanks in advance.
Thanks in advance.
Waza4
Re: NC23 rear disc
I'd say too many holes for the price they might crack, but how much do you use the rear brake?
cress87
Re: NC23 rear disc
True...I'm just debating whether it's worth the extra ~£30 for an EBC pro-lite one?
little nick
Re: NC23 rear disc
[quote="cress87"]Chaps,
I need a new rear disc because mine is slightly warped. quote]
It's worth a quick check before replacing. Ensure you do not have any corrosion or paint flaking on the rear wheel - where the disk mounts to it. If you do - it will deform the disk slightly - so it will act like a warped disk.
A quick clean up & remount the disk - could sort it.
cress87
Re: NC23 rear disc
Ok, I'll check that first ta. :)
Mikiboy
- Bike owned: RVF400 NC23 x 2 NC29 CBR4/600
Re: NC23 rear disc
get a breakers one. You should be using the front brake, not the rear. the rear is just for slowing or speed controlling at low speeds. A rear should last the life of the bike.
