WIRING UP COILS ON VFR400 NC24
speedy(delboy)
I am having a few problems wiring up the VFR4 NC24 coils (I have attached a pic below to help with explaining).
I have the obvious 4 coils and 8 wires as per the diagrame, now natural thinking tells me to put all the black/white stripes to the black terminals on the coils and the remainder on either the green or blue, but when i do this, all I get is a buzzing from the started solinoid.
I thought the solinoid was busted so put on another one but the same thing happens.
Can anyone suggest what I am doing wrong.
P L E A S E
P L E A S E
speedy(delboy)
Re: WIRING UP COILS ON VFR400 NC24
16 views and no help
The starter solenoid should have little to do with the coils, sounds like a battery issue to me.
Your wiring on the coils sounds right.
speedy(delboy)
I was using a battery charger, set to 12V, ??Stickshift wrote:The starter solenoid should have little to do with the coils, sounds like a battery issue to me.
RonniB
a battery charger don't have enough amps to crank even the smallest bikes, so charge the battery and try again. The relay is perfectly fine, just not enough current.
Ronni
Ronni
speedy(delboy)
Cheers Guys,
New battery arrived this morning, so now on charge overnight and will throw her on in the morning and try again.
Heres Hoping
Cheers, Phil
Heres Hoping
Cheers, Phil
