ingitor relay
jimfzr400
ingitor relay
dos any 1 know where i will find the ingitor relay on the bike or have a pic of it
- Variablevalves suck
Re: ingitor relay
Its under the left side panel, the rear one is the flasher relay and the one closer to the battery is the ignitor.
jimfzr400
Re: ingitor relay
i have all readY STRIPED the bike i have 2 full looms any iders as to what it looks like or a pic would realy help . As in gessing its not the starter relay with the 2 nuts on it thanks for yous time .
Re: ingitor relay
Hi Jim.
On the left side of the bike under the side panel you will have two small boxes, one has three wires connected and is the for the indicators and the other is the relay you are after its about one inch square and has four wires connecting to it. They are both fastened to the frame via small rubber couplings that slide onto a tange welded to the frame. it will be just above the regulator.
