What is this ?
				PARUS
What is this ?
Hi,
I'm again ask strange questions. What is this ? It looks like gear indicator, but it has 7 lights. Maybe this is battery indication?
- mrdidlydingo
Re: What is this ?
Gear change indicator dude !
				PARUS
Re: What is this ?
But we have 6 gears, this indicator has 7 lights.mrdidlydingo wrote:Gear change indicator dude !
Re: What is this ?
like the indicators you see n F1 cars - telling you your optimum time to change gear
				PARUS
Re: What is this ?
Cool. So, if all lights is on, you need to switch to highest gear. Correct?CMSMJ1 wrote:like the indicators you see n F1 cars - telling you your optimum time to change gear
- w00dzy
Re: What is this ?
I presume the first light can be set to light up at a certain rpm and then the rest follow perhaps up to 14.5rpm showing when to change up to the next gear..
				PARUS
Re: What is this ?
Yes, but bike not moving and as you can see on tachometer engine is stopped. Why there is 4 lights on ?w00dzy wrote:I presume the first light can be set to light up at a certain rpm and then the rest follow perhaps up to 14.5rpm showing when to change up to the next gear..
- w00dzy
Re: What is this ?
Not sure, possibly setting it up? or maybe all the lights shine up in sequence when you start the bike?
Re: What is this ?
It's a shift-i, an Aussie made bit of gear.
Good stuff, plenty of setup options.
http://www.ecliptech.com.au/main_win_sep06.html" onclick="window.open(this.href);return false;
						- royster81
Re: What is this ?
it was fitted about 20secs before that photo and was in the process of getting set up for the bike .PARUS wrote:Yes, but bike not moving and as you can see on tachometer engine is stopped. Why there is 4 lights on ?w00dzy wrote:I presume the first light can be set to light up at a certain rpm and then the rest follow perhaps up to 14.5rpm showing when to change up to the next gear..
It's not having what you want  but wanting what you've got....Loud ,Proud and Modified ....
