600 down pipes on 400
				sharpey
which model 600 downpipes will fit my 400 1wg 3en1????
				Taggyd
Re: 600 down pipes on 400
why you want the 600 ones? thought you'd got some already? rammy on here might have some propa downpipes?
As far as I know they don't fit (as in bolt straight on) they sit lower, burn the bodywork and of course don't have the exup valve.sharpey wrote:which model 600 downpipes will fit my 400 1wg 3en1????
				sharpey
yer i know but that dont matter bout how low they sit its not gona have any body work other than tail, just didnt know if there is a difference in the angle etc where they bolt on to the head, and no exup is grand save me having to take it out hehehe
Well the 600 is about 20mm taller than the 400 so there will be some difference but it will probably show at the back mount under the footpeg. The system will be lower to the ground too.
Up to you with the exup
				sharpey
ummm true do you have any other suggestions???
				Taggyd
open headers?
				martynfzr
ive got a full micron stainless system on mine it does sit a bit lower b ut i dont have the lowers fitted you do have to fiddle with the rear fitment b ut its not a big job
I think Sandy Bike spares do a non-exup system in stainless
