NC29, misfire + running on 3 cylinders
lazcbr29
Bike owned: kawasaki ar 50, Honda CBR 125
Post by lazcbr29 »
hi there.
basically ive had my cbr for 7 months now. in feb i decided to service it. i did the usuals, oil, oil filter, iridium spark plugs, air filter and coolant.
after the service it wasnt quite running right, it misfired ran on 3 cylinders on idle.
i posted on here and got a few replies. i got the carbs balanced as a few people recommended it.
it half solved it, it didnt do it as much.
today riding it to college, it started up normal, but now it only fires on 3 cylinders constantly below 3000rpm.
had few ideas if its not the fuel could it be my coils?? someone suggested new leads + caps??
any ideas/help from you ladies and gents would be much appreciated.
thanks
laurence
extra info. - nc29, r model, 110 main jet.
Wozza
Re: NC29, misfire + running on 3 cylinders
Post by Wozza »
Have you checked the valve clearances? This should be done before balancing the carbs.
leopard_pagan
Bike owned: used to have a NC29
Post by leopard_pagan »
check plugs-leads
lazcbr29
Post by lazcbr29 »
valve clearances where done at same time as carbs apparently.
plugs are under 1000 miles. + it doesnt change when you put diff plugs in...
and what im thinking is it might be fuel,
cos it only does it at low revs.
could my pilot jets be wrong coz as soon as you open the throttle and go above 3000 its fine??
cheers neway
laz
Wozza
Post by Wozza »
Your jet sizes should be:
Pilot - 35
Main - 105
Compression check might be an idea.
razortooth
Post by razortooth »
Are the correct sockets on the plugs? Had this problem long time ago - the bike ran like a tractor on 3 cylinders. I saw that i've mixed up the connectors from the 1st and the 2nd plug - the firing order wasn't right...
My will may be weak, but my backbone is strong
House MD
lazcbr29
Post by lazcbr29 »
razor - just checked again theyr'e all on correct...
if it was ht leads or caps would the problem go away when revved, it literally only does it on tickover or below 3000rpm???
cheers again
laz
chris
Post by chris »
Here is a great way of checking where your problem lies.
Take the air box off and squirt some EZ start down the inlet of the offending cylinder when the bike is running. You only need a little bit.
If it briefly comes to life and runs on all 4 for a little while it means you have a fuel problem and need to check the carbs again. Could be blocked pilots or something.
You can tell if the cylinder comes to life by feeling the exhaust header carefully - it will get warmer.
If it does nothing then chances are you have a duff component in the HT setup.
