NC24 Sump removal
christ044
- Bike owned: NC24
NC24 Sump removal
Got my engine finally back into the frame again, only thing is i forgot to swap over the sump as the one on the bike has a small crack in it (no oil leaking but best to change it before hand!)
Does anyone know of a way of changing the sump whilst the engine is still in the frame?
I just cant seam to get anything on the rear centre bolt.
Re: NC24 Sump removal
Surely it'll hit the collector box even if you get it un-done?
I have modded the collectorbox on mine by chopping the rear pipes and welding a collar on them with some simple jubille clamps.
Now the rear pipes stay attatched but the collectorbox just slides off allowing a quick whip off of the sump.
With a standard system the only way I know of is to remove the engine to get the exhaust off
