Oil blowing out of the side of engine?
ian
Post by ian »
(bike is a 1997 super four)
After doing the shims and putting the bike back together, I went for a test ride. When I got back though, I realised my left foot, and left side of the bike - were coated in engine oil!
It seems oil has been blowing out of the hole in the picures below:
Does anyone know the purpose of these holes? the other side has one, which is fine - as they were before I did this work.
Some sort of breather perhaps? When rebuilding the cams the lubrication probably over filled the oil.
Ian
amorti
Regular Member
Bike owned: CB-1, MSX125
Re: Oil blowing out of the side of engine?
Post by amorti »
They are there to let water that gets into the spark plug recess out. So either you have a spark plug on the LHS that isn't tightened correctly, or you didn't seat the rocker cover gasket correctly, or it's split.
Damn I'm good. Next!
ian
Post by ian »
cheers for that Amorti,
will check it out
Ian
