why wont it start!
rickstar
- Bike owned: gsxr 400 gk76a
why wont it start!
i have a gk76a i replaced all the plugs and it started once, now it wont start or bump start. please help!!!!!
wullvfr
- Bike owned: zx9r c1
Re: why wont it start!
does the choke work?
william
william
rickstar
i think so the cable is ok, it started once and now wont, it just turns over. thanks
wullvfr
just need to check the usual checks.........is there fule getting to the carbs and the cylinders?
is there a spark?
william
is there a spark?
william
jamierooney
Rickstar,
is there a spark off the plugs/leads?
What model plugs are you using?
get these 2 answers to us, and we might be able to help you along.
J
J
rickstar
im using ngk cr8ek and there is a spark. thanks
jamierooney
im thinking yu most likely have a fuelling problem so. Try cranking it off the start button for about 10 seconds and take note if theres little puffs of smoke comin from the exhaust; but get a plug out straight away and check if theres fuel on it. Any liquid will mean fuel, black stuff is oil (bad sign).
After this it may be worth cleanin yur engine mount brackets, cos yu can have spark, but it will dissapate quickly without firing if theres a dodgy path to neutral for the plugs to earth.
viffer4
Do gsxrs have a similar vacuum fuel tap system as NCs?
rickstar, if you've had the tank off make bloody sure fuel is getting from tank to the carbs.
sounds to me like it might have used the fuel in the carbs in the 1st start, then not got any more from the tank,
and stopped!
and stopped!
jamierooney
+1viffer4 wrote:Do gsxrs have a similar vacuum fuel tap system as NCs?
and stopped!
prime setting also there to fill up your carbs too.....
