Squeaking when front brake applied
cakeman
Post by cakeman »
Hi, my brakes have recently started squeaking when i apply the front brake. i dont feel any vibration through the lever, just hear a squeak. its not a constant squeak through braking, its an on / off squeak, which leads me to belive it might be something to do with the disc when it passes through the brake calliper.
Any info would be appreciated.
Cheers.
viper_biker
Re: Squeaking when front brake applied
Post by viper_biker »
At first guess, you need to replace your pads. Could be metal on metal
cakeman
Post by cakeman »
looks like there is plenty of meat on the pads still
is it a high pitched squeek?
check your bolts are all tight and also check the rubber boot on the mastercylinder - mine has a little squeek...
