hrc filter mod
Posted: Fri May 30, 2008 4:31 pm
by shokrabi
Does anybody still have the write up on this mod? Also has anybody done it and is it any good for my track bike. The carbs will be set up.
Re: hrc filter mod
Posted: Fri May 30, 2008 8:51 pm
by Speedy
I think you can find a guide for that on akhara.com
Re: hrc filter mod
Posted: Fri May 30, 2008 10:48 pm
by shokrabi
the carb mod was on there but not the hrc filter change
Re: hrc filter mod
Posted: Sun Jun 01, 2008 11:31 pm
by Cammo
I don't think that messing around with non standard filters is a good idea.
The carbs need significant set up changes, and you'll always get a flatspot between the transition from needle to main jet if you don't modify the carb air jets.
It's not worth the trouble just to get probably 0.5 more hp.
Re: hrc filter mod
Posted: Mon Jun 02, 2008 3:46 am
by superlite
There is no HRC filter mod - the HRC set-up doesn't use a filter. Are you referring to replacing the guts of the standard filter with aftermarket, re-usuable foam?
