hrc filter mod
shokrabi
hrc filter mod
Does anybody still have the write up on this mod? Also has anybody done it and is it any good for my track bike. The carbs will be set up.
- Speedy
- Bike owned: RVF400RR, ER6n
Re: hrc filter mod
I think you can find a guide for that on akhara.com
shokrabi
Re: hrc filter mod
the carb mod was on there but not the hrc filter change
Re: hrc filter mod
I don't think that messing around with non standard filters is a good idea.
The carbs need significant set up changes, and you'll always get a flatspot between the transition from needle to main jet if you don't modify the carb air jets.
It's not worth the trouble just to get probably 0.5 more hp.
- superlite
- Bike owned: TLS, LB80 x 2
Re: hrc filter mod
There is no HRC filter mod - the HRC set-up doesn't use a filter. Are you referring to replacing the guts of the standard filter with aftermarket, re-usuable foam?
'Take it to the Back'
