Parts Question...
Iccle
- Bike owned: CBR400RR NC29
Parts Question...
OK, so looking at the Microfiche for the carbs on an NC29, I was considering checking and replacing the Diaphragms / Sildes.
So, Fiche Index says "E17-1"... Fiche "E17-1" marks the part as number "16"... Part Number "16" = 16111MV4000
Off to DavidSilverSpares...
16111MV4000 = PISTON,VACUUM !D >>> DISCONTINUED
Help! - Anyone know a source for these?
FYI...
Part number 16010MV4000 has been superceded by Part number 16010MV4780... which is GASKET SET,A *G (What appears to be all the gaskets and o-rings) is available although this part will be special ordered in for you from Honda. Delivery time should be between 5 - 7 working days depending on stock availability from Honda. For the sum of £14.63 (inc VAT) per Carb.
FYI...
- leopard_pagan
Re: Parts Question...
no idea why they (Honda) change the numbers.
stimpy
do they need replacing?
stimpy
stimpy
Iccle
I don't know until I take the carbs apart, but I don't want to be the position where they do and I can't get them.stimpy wrote:do they need replacing?
stimpy
stimpy
chances of them being stuffed are fairly slim...but look,if they are,worst case is u could pick up another set of carbs cheap off flea bay
stimpy
stimpy
Waza4
You could always try phoning David Silver SALES HOTLINE 01728 833020
