Which Screw
Which Screw
There is a lot of advice about which screw and pilot screw should be set to what to run well,
but anyone got any images of which screw on the gsxr 400 GK76a carbs does please ?
- Variablevalves suck
Re: Which Screw
Check out Tony Sleeps article,
http://tonysleep.co.uk/gsxr400carbs" onclick="window.open(this.href);return false;
Altho he calls the pilot screw an idle screw.
If you need o'rings i supply full set.
Chris.
Chris.
Re: Which Screw
Located at the bottom of the carbs. Generally 1.5 turns out.
Uncrew it all the way out to remove - there should be:- 1 washer, 1 rubber o ring, 1 spring, 1 screw.
Re: Which Screw
TeamGSXR wrote:Located at the bottom of the carbs. Generally 1.5 turns out.
There are 4 external to the carbs, no washer, no o-rings, just a steel needle with a screw head thats 1
the rest are inside the carb :
there is one in the carbs with a hex head with a smaller screw inside it, with a tiny hole - the needle has 8 holes in its side... - thats no 2 ?
there is one way down deep in a hole right of the hex head - thats 3 ?
and there is one screw which has a hole it into the left which makes 4 ?
what are they all please ? lol..
Re: Which Screw
Re: Which Screw
Oh... well thats really simple..
once i have purchased the missing bits off the bikes carbs, i'll get started...
so far its missing a choke return spring and the o-rings / washer and springs from the idle screws
thanks fella
:D
thanks fella
:D
Re: Which Screw
LOl bloody pikeys giving you a bike with missing parts. Im banditmax from btf by the way. Im guessing robinsons foundry will be your best bet for the springs/washers. Or maybe fowlups.
Re: Which Screw
lo mike
fancy seeing you here lol...
I'll nip into fowlups and get some bowl gaskets and the needles springs etc.. assuming they are not order only.
sort of annoyed that its missing.. but then it might explain why he could not get the thing running off the starter
which hopefully means i'll be on two wheels a bit quicker
Re: Which Screw
13291-29900: WASHER
£0.57 4 £2.28
13268-47070: SPRING
£2.03 4 £8.12
13258-33C00: SEAL
£6.59 4 £26.36
Subtotal: £36.76
Shipping: £2.61
VAT @ 15.00%: £5.90
Total: £45.27
Those float bowl gasket seals are a bit bloody expensive lol.
£0.57 4 £2.28
13268-47070: SPRING
£2.03 4 £8.12
13258-33C00: SEAL
£6.59 4 £26.36
Subtotal: £36.76
Shipping: £2.61
VAT @ 15.00%: £5.90
Total: £45.27
Re: Which Screw
where be that from mate ?
