hybrid with r6 shock.
				hunter
I,am hoping someone will giv me a measurment,
i am fitting a nc30 swingarm to a 3tj frame,and i need a measurment from the centre of the swingarm spindle to the floor,the bike must be upright off stand and on level ground,and measurerment must be taken from centre of spindle.please.
Could,you also tell me,show me, what fits between the frame rails behind the the petrol tank,is it a seat brkt,tank brkt,it's held on with 2 6mm bolts.thank's in advance.
see photo.
see photo.
Re: hybrid with r6 shock.
The fuel tank ... it has a boss welded onto the bottom and a long bolt through it that squeezes the frame togetherCould,you also tell me,show me, what fits between the frame rails behind the the petrol tank,is it a seat brkt,tank brkt,it's held on with 2 6mm bolts.thank's in advance.
				hunter
Evilchicken0,you say it's a long bolt but the frame is threaded both sides.
				fzrtim
- Bike owned: FZR400 FZRhybrid FZR600 RSV1k
I think the last owner of the frame must have done some mods on the frame judging by the fact they seem to have tapped out all the holes!
Just a long bolt on both of mine too!
				hunter
Tim,this is a 4dx frame,just like the top shock mount they semm to be different to other 3tj frames.
				fzrtim
				hunter
Cheers m8,just what i wanted to see on the tank.
But the measurementi was hoping to get was as in photo below.
Also,one other thing is the measurement, eye to eye of your r6 shock when fitted no rider on board.
thanks again.
thanks again.
				fzrtim
Sorry for delay in reply. The bolt hole you have pointed out in the last drawing is actually the rear subframe top mount. All the same i measured that to the floor. It measured 715mm to the centre of the bolt.
I have a spare standard 400rr shock lying around the garage, when i locate it i will measure the length of it for you!
Hope this helps, Tim
				hunter
thank's for that one tim,i can get on a bit with the nc swingarm conversion,
the shock measurment has got to be the r6 shock,and when fitted to the bike,again no rider just the weight of the bike,and from mounting eye to eye,no extention piece
