NC30 ignition curve
Posted: Tue Mar 24, 2009 6:27 pm
by whizzo944
Anyone point me to a link or whatever for an Ignition curve for either a standard NC30 or HRC ignition box?
I am in the process of fitting a programmable ECU to my NC30.
Thanks in advance,
Dave.
Re: NC30 ignition curve
Posted: Tue Mar 24, 2009 9:48 pm
Hi Whizzo.. Welcome to the site.. Go have a look in the tech section about the programmable ignitions (thread by me..)
I have several maps used and have created various advance graphs to show the differences..
Stick about, go tell us about yourself in the newbies
Posted: Sat Apr 18, 2015 9:07 pm
by lutorm
Hey, I was looking for this, too, but I can't find this post being alluded to. Anyone have a link?
Posted: Sun Apr 19, 2015 9:51 am
by whizzo944
Hello Lutorm :-)
If you follow this link, I have posted the standard and HRC ignition curve graphs there.
http://s870.photobucket.com/albums/ab263/whizzo944/
Dave
Posted: Sun Apr 19, 2015 11:33 pm
by lutorm
Cool, thanks!
Are those wiggles really real? I would have expected the advance to be a smoothly increasing function with rpm, not go up and down?
Posted: Mon Apr 20, 2015 4:58 pm
by whizzo944
Hello,
I think the dip at 5000 rpm might have something to do with noise testing, not the engine running well :-)
Dave
Posted: Sat Sep 19, 2015 9:35 pm
by lutorm
Now that I'm all set up to run the ignition with my Microsquirt, I finally got around to measuring the ignition curve with the stock ignition unit. The data clearly resembles the previously posted curve, including the dips at 4-5k and above 7k, but there's an overall shift in that my points are higher at low rpm and lower at high rpm.
Posted: Thu Mar 16, 2017 6:37 am
by lutorm
Hey Dave,
Revisiting this thread now that my bike is running with the Microsquirt. I measured the stock ignition timing very close to your curve. However, now that the bike is running, I'm getting pretty severe knock if I try to run anything above 35 degrees at the first peak around 6-7k RPM, even at a lambda of 0.86. Did you end up using the timing curve as measured?
I guess I should double-check that I have the timing right...
