Clutch cable probs - lever hitting speedo
regcheeseman
The adjuster on the end of my clutch is hitting the speedo and preventing correct lock.
Also the cable routing seems wrong (despite following manual with genuine part) - The cable is being presented to the clutch lever at and awkward angle, as if the cable is too long.
I do like my levers set below horizontal, but lifting them up cures the interference with speedo but i'm still left with a less than perfect cable routing.
The cable runs between the yokes and along the left hand main frame spar.
Is this normal? Do the levers need to be set near horizontal?
Re: Clutch cable probs - lever hitting speedo
They all do it...
NOt seen an NC yet without speedo scarring fomr the clutch lever..
