3tj calipers
3tj calipers
okay got a set of 3tj calipers for the 1wg but they sre split im as there are 2 different size pistons im guessing when they go back together it should be same size pistons facing each other
cheers martyn
cheers martyn
Re: 3tj calipers
yep. you got it in one
Re: 3tj calipers
Don't blue spots fit your forks ??? 100mm bolts spacing whereas 3TJ's are 83/85mm
Re: 3tj calipers
nope mine ar the early genesis forks
