vfr-rvf swingarm
Posted: Mon Mar 09, 2009 4:55 am
by randallbass
hey guys is there any difference between an rvf and a vfr (400) swingarm?
cheers
Re: vfr-rvf swingarm
Posted: Mon Mar 09, 2009 5:18 am
by royster81
yes ,the rvf is narrower at the pivot where it joins the frame,also the vfr runs an arm for the caliper bracket whereas the rvf doesn't
Posted: Mon Mar 09, 2009 9:56 am
by randallbass
so with a spacer it would fit? how does the caliper mount do you have to get an rvf caliper?
cheers mate
Posted: Mon Mar 09, 2009 10:53 am
You cannot fit the swingarms easily
RVF arm is different enough that it would not be a case of using a spacer to fit the other..
Posted: Thu Apr 09, 2009 9:35 pm
by hunter
Royster would you be kind enough, to post the drawings showing the difference between these swingarms.thank you.
