vfr-rvf swingarm
randallbass
vfr-rvf swingarm
Post by randallbass »
hey guys is there any difference between an rvf and a vfr (400) swingarm?
cheers
royster81
Re: vfr-rvf swingarm
Post by royster81 »
yes ,the rvf is narrower at the pivot where it joins the frame,also the vfr runs an arm for the caliper bracket whereas the rvf doesn't
randallbass
so with a spacer it would fit? how does the caliper mount do you have to get an rvf caliper?
cheers mate
You cannot fit the swingarms easily
RVF arm is different enough that it would not be a case of using a spacer to fit the other..
hunter
Post by hunter »
Royster would you be kind enough, to post the drawings showing the difference between these swingarms.thank you.
