O-Ring Sizes
				Steve
O-Ring Sizes
I'm replacing the o-rings in the carburettors, and the old ones coming out of the slide holder look like a slightly  thicker section than the 10x1mm recommended in Tony Sleep's article.  Is there a slightly thicker one, like maybe 10x1.25mm or is 10x1mm the right size?  Likewise, the old ones on the idle adjust screw look like about 3x1mm and the 3.5x1mm that Tony recommends are a very loose fit on the screw.  Will these work, or do I need to get some 3x1mm?  Thanks
				GIXXER_PILOT
Re: O-Ring Sizes
I have the o ring sets that is in Tonys guide and i have the stock mixture screws from suzuki with the funny shaped one between the jet holders. If you need them let me know.
				Steve
Re: O-Ring Sizes
Thanks for your reply.  I'll send you an email.  Can anybody else confirm the correct sizes?
				Steve
Re: O-Ring Sizes
I haven't heard anything from you. Did you get my email?GIXXER_PILOT wrote:I have the o ring sets that is in Tonys guide and i have the stock mixture screws from suzuki with the funny shaped one between the jet holders. If you need them let me know.
