recommend me a compression tester
				deano
Hi,
I want to do a compression test on all the cylinders on my nc30 can anyone recommend me a good compression tester to use with the nc30 and where to get it.
thanks in advance.
deano
thanks in advance.
deano
- Jon
Re: recommend me a compression tester
Pretty sure you will not buy a copression tester to fit the NC30 plug, I knocked the centre out of a spark plug and silver soldered up an adaptor to do mine.
regards
jon
						regards
jon
as what jon has said since only the NC30 / NR750 and possible a select few other bikes use the tiny plugs compression testers are not readily available.. it's not too difficult if you know someone with a lathe to knock you one up.
I used a piece of copper pipe threaded to the appropriate size last time.
