Getting the spring of the standard shock
Whats the best way to get the spring off the standard RVF shock? My new ohlins spring hasnt turned up yet so gunna try the standard spring on the RS250 shock.
Has anyone tried this? or has anyone run a rvf with a RS250 shock and spring?
The shock has been reworked by maxton to suit a 12stone rider and im 11 stone, do you think id get away with just cranking up the preload and comp and keep the RS250 spring?
Cammo
Re: Getting the spring of the standard shock
Post by Cammo »
Drunkn Munky wrote:do you think id get away with just cranking up the preload and comp and keep the RS250 spring?
Not a chance, the spring rates are way different to what you need as the linkage ratios are very different.
Putting the rvf spring on would be a better idea.
Spike16
Post by Spike16 »
out of interest how much did it cost you to get maxton to redo it adn set it up for your weight?
iv just got an rs shock and need a similar thing done
Well i got the standard rvf spring on after much f**king about with some spring compressors that were way to big for bike springs. Result......way to stiff, not sure why but sod it i'll just have to wait for ny ohlins to turn up and get the shock rebuilt to suit the RVF.
Spike, I didnt have the shock reworked by maxton, the previous owner did but it was on his RS250. I have had one done before tho and it cost around £100. If your anywhere near surrey id recomend steve jordans.
While im on the subject does anyone know whats involved in rebuilding the shock to suit the RVF? Mine has been rebuilt and setup by maxton but that was when it was fitted to a rs250 so is it just a matter of changing the spring or will it have to be revalved different to suit to RVF?
Simon_Ed
Post by Simon_Ed »
i run a rs250 shock with the standard spring, had it on for a while now, not had any probs with it to be honest. I've always finished top 5 or top ten so its not too bad i spose
Simon ed, did you cut the rvf spring down to get it on the rs shock? cos i had a nightmare compressing it enough to get it on, and then once it was on i had bugger all preload adjustment as the collors were right at the top of the adjustment range.
Simon_Ed
Post by Simon_Ed »
i know its definitely not been chopped, a mate prepped it for me and put the shock and a jack up plate on the bike
Simon_Ed wrote:i run a rs250 shock with the standard spring, had it on for a while now, not had any probs with it to be honest. I've always finished top 5 or top ten so its not too bad i spose
We when you say standard spring do you mean the rs250 or rvf spring?
Simon_Ed
Post by Simon_Ed »
the standard rvf spring on the rs 250 shock
wullvfr
Bike owned: zx9r c1
Post by wullvfr »
Drunkn Munky wrote: Result......way to stiff,
Drunkn Munky wrote:Simon ed, did you cut the rvf spring down to get it on the rs shock?
i think cutting the spring down to fit easier would result in the same,too stiff :poke: ....possibly :?
william
