Gaskets for Yammoto half system
For those that have fitted yammoto systems is there meant to ba a gasket to join the system to the standard front pipes?
I brought some new gaskets before i recieved the system but upon fitting the yammoto system slides neatly over the standard downpipes without the gaskets.
So what are you guys using? a bit of exhaust paste or just nothing?
viper_biker
Re: Gaskets for Yammoto half system
I never used anything, but it's probably best to use something like a silicon sealant to do the trick.
For all the interference fit pipes I used nothing at all to seal the pipes.
You could always fit it and see what blowby you get and seal it if it looks bad?
- DAC
- Bike owned: 89 NC30
You won't need anything for the Yamamoto system, it fits fine just as it is.
Regards,
Dave.
Regards,
Dave.
RWB NC30
