Carb removal ?
				Trigger
Carb removal ?
Anyone help ?
Need to know the easiest way to remove carbs from 1990 GSXR 400 gk76a.
Step by step if possible.
Many thanks.
Many thanks.
				arkell
Re: Carb removal ?
yeah..
rhs fairings off, tank off, loosen airfilter, loosen jubilee clips on the carbs, slide out to the rhs
also lots of swearing!
read this for better description:
http://tonysleep.co.uk/gsxr400carbs" onclick="window.open(this.href);return false;
				Trigger
Re: Carb removal ?
I'm good at swearing ..
				Gavsta
Re: Carb removal ?
"A note about the carbs. They are a pig to remove. You have to take the tank and all hoses off, the battery, the battery cage, the entire sodding airbox assembly to even get at them, and then you only have about 4mm of space to wiggle the bastards out. "
