Leaking exhaust system!
Lasse
Post by Lasse »
Hello guys!
I have a leaking exhaust header on the VFR, it's at the joint on the headers that run below the engine.
It's a hole that's been punched through it.
Any systems thats worth buying or is it all looks? Maybe someone has a good set of originals? :)
Kind regards, Lasse
randallbass
Re: Leaking exhaust system!
Post by randallbass »
if it at the bottom where you dont see it just wrap a can around it with some fiberglass wrapping and some lockwire to hold it shall do that trick nice and quickly :) :) or weld it up
royster81
Post by royster81 »
or take your system off and take it to someone who will weld on some stainless collars in piece of the old mild steel ones,most cost £60,refit exhaust and enjoy
or sell the old rotting one you have (good luck as everyone has at least one rotting one) and spend £200+ for a half system that you might need to find a can etc for ....
i'd got for option one
