Page 1 of 2
oil leak??
Posted: Sat Jan 03, 2009 12:26 am
by zxrkat
My vfr nc30 leaked oil from somewhere on its first trackday, i bought the bike 4 months ago and it had been stood up for a year, i had it checked out, carbs cleaned and it went fine, took it to Donny and it managed 3 sighting laps, oil all over front and dripping into bellypan, cant see where it has come from, doesnt leak on tick over, no oil in airbox?? Stumped, any help most welcome.
Re: oil leak??
Posted: Sat Jan 03, 2009 10:12 am
loose oil filter? easily done...
welcome too by the way!
You might have to get down and clean it up and then run it - but dibs for me would be to nip up the filter first..
Re: oil leak??
Posted: Sat Jan 03, 2009 10:28 am
by benny1380
Doesn't leak on tick over? Are you sure theres still some oil in there? Just checking!
Yeah, see if you can tighten the filter up if not its the hard way, fairings off, clean it all up (brake cleaner is good) check the oil level then run it, if its slashing out shouldnt be too difficult to find
good luck
Re: oil leak??
Posted: Sat Jan 03, 2009 10:30 am
by Spike16
yeh it'll either be loose oil filter or cracked sump, on a gasket gone somewere but that shouldnt have leaked much
Re: oil leak??
Posted: Sat Jan 03, 2009 10:44 am
by Simon_Ed
check the front, like CMSMJ said and check the oil filter, think u need to strip the fairings off it, jet wash all the oil off and check oil pipes, breather pipes etc
Re: oil leak??
Posted: Sat Jan 03, 2009 11:07 am
by royster81
possible a front rocker cover gasket,i think mine is on it's way out and i have a little oil around my front head which runs down to the filter
Re: oil leak??
Posted: Sat Jan 03, 2009 9:35 pm
by hunter
Re: oil leak??
Posted: Sun Jan 04, 2009 1:19 pm
by dx400r
Check the timing inspection cover too, its happened to me before...on a 150mile journey.
The oil sends to soak into the spongy stuff on the lowers and then when thats taken all it can it dribbles down to the middle and looks like its coming from the front end.
Re: oil leak??
Posted: Tue Jan 06, 2009 12:44 am
by zxrkat
thanks for all the replies guys, oil filter will be checked asap, but it looks clean, oil is coming from higher up, checked front rocker gasket and all clean, will give inspection cover a look next, thanks again, anyone in local area to me(southampton) welcome to have a look.cheers
Re: oil leak??
Posted: Tue Jan 06, 2009 1:13 am
by Spike16
im in winchester but am very busy for the next 3 weeks with my a level exams so no can do til after then, sorry
