RE:Touring on a CBR400 - What storage do you fit?
marty400
Post by marty400 »
Hiya All,
I would love to take the NC29 on tour. What storage have you fitted - that worked?(The Oxford old tank bag and "Ride" Pillion Bag - that fits on the 1996 cbr600- does not fit well on the CBR400! Worse luck!)
1) The Ventura system - does all that tubing add loads offweight onto the Bike?
2) Oxford side panniers - Do they fit the curvy rear end?
3) Do any other side panniers work?
4) Is there a good strap on pillion bag that would fit?
5) Tank Bag - Is there a good bag that would fit? Or is the space available simply too small and restrictive.?
6) Rucksack - an aching no no for touring?!?!!?
7) Security - Do you keep a big fat Chain under the pillion seat?
Hope you can advise on what works best on a NC29!
Martin
Matchlessman
Re: RE:Touring on a CBR400 - What storage do you fit?
Post by Matchlessman »
Hi,
Ive used oxford sport panniers a fair few times on my NC23 and they are great. You need to get them far enough back that they are very close to the indicators but they work really well.
My only negative comment on the oxford stuff is that the fixings seem to be a bit rubbish. all of the straps seem bad at tightening. Ive ended up using long strips of velcro rather than the straps that came with them.
Oh, and to answer the questions.
Tankbag - i find it gets in the way, its right where you want to tuck in.
Rucksack - ive only toured with one once and it was a nightmare- i hated it. Bumbag for your bits and piceces is the better option - get a decent one though, i had one that the buckle started to randomly unclip. It got replaced before I lost it.
Tailpack - ive only had the oxford cheapy one and it worked ok. I used it a couple of times but then bought the panniers. I didnt need it after that.
stuff under the seat - if the bike is loaded up with kit, getting anything out from under the seat is a nightmare. tools, bikelock, spare bungies etc etc travel in the outside pockets.
marty400
Post by marty400 »
Matchlessman wrote:Hi,
Hiya MM,
Hey hey, I live in Bristol, the same side of the country as you! Give me a shout if you fancy going out for a spin sometime this summer!... over the bridge, brecon becans spring to mind! 8)
Thanks for the advice. I'm going to look on the web now for some xmas sale deals!
Roll on the summer of 2009!
Martin
marty400
Post by marty400 »
Jolan
Bike owned: NC29 / TT600R / STR '11
Post by Jolan »
Most of the trips i travel like this:
Also i use transparant stickers to cover the sides of the rear fairing against marks and dirt from the straps.
Tank bag is great if you don't want to race it on the autobahn. If you do, the topspeed is limited to 200 :roll:
But it's nice to grab the easy stuff when you stop for fuel. It is also big enough for the weekend trips, and the Balance of the bike stay's in the middle.
marty400
Post by marty400 »
Jolan wrote:Most of the trips i travel like this:
Hiya Jolan,
That looks a proper Tourer! 8)
Is the back all stable though? It looks like there is only one bungee hook going on there!
....hhhmmm.... I'm going to give the Oxford magnetic tank back one more go! Perhaps ride around the block, to see if I can get use to it!
Have you ever looked at that Kruiger Tail pack luggage? Rate it?
Martin 8)
Jolan
Post by Jolan »
It's very stable if you strap it good and tight. I don't have experience with bungee hooks, i think that you can't get it up to a tension that hold that heavy weight. Or you need more hooking points. You can also use the pillon pegs!
marty400
Post by marty400 »
Jolan wrote:It's very stable if you strap it good and tight. I don't have experience with bungee hooks, i think that you can't get it up to a tension that hold that heavy weight. Or you need more hooking points. You can also use the pillon pegs!
Hiya Jolan,
Straps instead of bungees eh? I'll look into.
RE:Tank Bag
* Doesn't it get in the way big time?
- You can see the speedometer!
- You can't get below the Screen when gonig at speed
Martin
Jolan
Post by Jolan »
I think that a tankbag is even relaxer on long trips. Surely on the highway, because you can rest your upper body on it, so it's quit comfortable. But you musn't be in a hurry, above 150 isn't fun because you can't tuck in behind the windscreen.
And you can see your speedo indeed!
